Brief Description: Shape (Rage), Sand, Fill Pinholes on Both Tips
Today I removed the horizontal stabilizer from the fuselage and masked everything off except the two fiberglass tips. I then filled in the low spots with Evercoat Rage, sanded everything smooth, vacuumed and cleaned with Acetone, and then filled the pinholes with Wonder-Fil
Right tip of horizontal stabilzer shaped, sanded, and pinholes filled
Left tip of horizontal stabilzer shaped, sanded, and pinholes filled
Loehle Wonder-Fill pinhole filler drying on horizontal stabilzer tip
