Brief Description: Debur Rear Spars; Prime Aileron Brackets
After the aileron and flap gap fairings were match drilled to the rear spars, I removed them and then deburred the rear spars and outboard top skins. This was done in between primer coats for the aileron attach brackets and reinforcement plates.
Debur left rear spar for brackets and gap fairings
Debur right rear spar for brackets and gap fairings
Prime aileron attach brackets and reinforcement plates
