Brief Description: Right Tie Down Spacers Drilled to Spar
I clamped two of the tie down spacers to the right spar and then used the 3/16 holes in the spar to back drill the spacers. I also measured and drilled the single match-hole in each of the two tie down pieces. These will be used to locate the tie down pieces on each spar so the rest of the holes can then be back drilled.
