Dan's Web Site
Date:  7-1-2011
Number of Hours:  1.00
Brief Description:  Wing Root Fairing - Top Aft Platenut - Both Wings
I made a mistake and drilled the rivet holes for the top aft most nutplate for a normal K1100 dimpled nutplate when I should have drilled for a special single-sided nutplate that needs to be installed parallel to the rear spar. I assume this is specified for two reasons - 1.) for clearance for the flap, and 2.) so the nutplate will sit flush on the skin and not interfere with the flange of the rear spar. I ended up just installing 2 stand-alone rivets in these mistakenly drilled holes and then drilled and installed the single-flanged nutplate instead. At least I was consistent and both wings match :-)
Special nutplate riveted to trailing edge of right wing needed to provider clearance for flap movement
