Brief Description: Sand, Clean, Tape, Paint Inside of Lower Cowl
Today I used a dremel sanding drum to knock down all of the excess micro blobs on the hinges of the lower cowl. I then vacuumed and cleaned with acetone, taped off the hinges, and then brushed on the first coat of Rustoleum high-gloss white enamel.
Lower cowl painted with Rustoleum high-gloss white enamel
