Brief Description: Install Top Cowl While Inlet Ramps Cure
Van's instructions indicate the top cowl should be installed while the epoxy is drying on the inlet ramps since they will stiffen the top cowl and potentially change the shape of it otherwise so I covered the engine in plastic to protect it against drips and installed the top cowl.
Engine covered in plastic to protect it from dripping flox
Top cowl installed while flox cures on the inlet duct ramps
