Brief Description: Install Parts 4,5&6, Clamp and Drill 5&6 Together
Now that part 6 can be fully secured to the engine block via part 15 along with the spacer for the mounting bolt, I clamped and marked the flanges of parts 5 and 6 together and used a right-angle drill to drill 4 alignment holes while the assembly was on the engine. Then I removed everything and drilled the remaining holes.
Parts 4,5&6 installed on engine, clamped together, & 4 alignment holes drilled with right-angle drill
