Today I sanded the lower cowl for the hinges, cleaned both the cowl and hinges with acetone, and then micro'd and riveted all of the hinges to the cowl. I installed the other half of the hinges with the pins to make sure the micro cure and block off any of the eyelets, etc.
Left side of lower cowl hinges micro'd and riveted in place
Right side of lower cowl hinges micro'd and riveted in place
