Brief Description: Replace Right Caliper O-Rings with Viton O-Rings
The RV list contained several recommendations to replace the brake caliper o-rings with viton o-rings which stand up to heat much better. I'll be using the new mil-spec brake fluid as well which has a higher flash point so hopefully I won't have any brake fires like others have experienced.
Right caliper and piston removed, new viton o-ring installed
