Dan's Web Site
Date:  9-26-2005
Number of Hours:  1.00
Brief Description:  Trim Vents; Drill F793 Brackets to Skins
I'm not accustomed to working with plastic. I tried trimming the plastic vents and funnels using a utility knife but that didn't work too well. I ended up cutting these on the bandsaw and then sanding the edges smooth on the bench sander. They turned out great. I then clecoed the vents to the panel and used them to positon the F793 attach brackets to the side skins. The side skins were prepunched so there was not much play on where these brackets could be positioned. I had drawn centerlines on the flange of the bracket and was able to align the brackets to the skins as well as the vents.
Plastic vents and brackets rounded according to the plans
Left F793 vent bracket drilled and clecoed to side skin
Right F793 vent bracket drilled and clecoed to side skin
