Dan's Web Site
Date:  9-17-2005
Number of Hours:  1.00
Brief Description:  Match Drill Forward Fuselage Structure
The next step was to match drill all of the forward fuselage components. I also drilled the F743B attach angle to the F643-1 center rib only. It will be drilled to the firewall after drilling the rib to the top skin to make sure it is positioned properly first.
Forward fuselage components match drilled
F743B attach angle drilled to F643-1 rib only
