Brief Description: Drill F732E Side Angles to Channel
The next thing I did was remove the canopy frame and top support angle from the fuselage. I wanted to match drill the second row of holes in the aft end of the channel to the spacer. One row of holes goes through the channel, spacer, F706 bulkhead flange, and top skins. The second row of holes just go through the channel and spacer. Once this was done I clecoed the canopy frame and top channel back onto the fuselage and positioned and drilled the F732E attach angles to the aft face of the canopy frame and to the sides of the forward end of the F732A channel.
Match drill second row of holes in channel using spacer holes
F732E side angles drilled to canopy frame and top channel
