Brief Description: Mark Outer Flange Rivet Pattern
I'm on-call this week so I don't have much time to work on the plane. I did manage to layout the rivet pattern along the outer flange of the canopy frame channels tonight. I used the same masking tape technique that I used on the inner flange. Once the rivet pattern was marked on the outer flange I center-punched all of the intersecting lines.
Outer flange masking tape marked with rivet pattern
