Brief Description: Elevator Pushrods: Measure/Cut/Drill
The next thing that I worked on today was the elevator pushrods. I cut both the forward and aft pushrods to length. I then did the masking tape trick on each end to evenly mark where each rivet hole would go. I then drilled the rod ends to both ends of each pushrod.
