Brief Description: Drill / Split Center Support Block
On to the flaps... I clamped the center support block to the drill press table and drilled the two mounting holes. I then used the bandsaw to split the block so it can be slipped around the actuator arm. I then positioned everything in the fuselage, clamped the center support block in place and used the holes that I just drilled as a guide to drill the holes in the floor and flange of the tunnel rib.
