Brief Description: Rivet Clips to Stiffeners; Rivet Gussets
I followed the plans and riveted the attach angle clips to the forward side stiffeners. I also riveted the F-684 gussets to the firewall brackets and angles. I had to grind down the 4" no-hole yoke somewhat so it wouldn't ding up the steel firewall brackets. I broke out the touch-up paint again to doctor up the steel brackets and the aux fuel pump bracket.
Attach clips riveted to stiffeners; gussets to firewall
