After the primer dried I riveted nutplates onto the F902 forward bulkheads and installed the rudder cable snap bushings. I then started working on the forward bottom skin. I used the soldering iron to remove the plastic around the rivet holes, deburred everything and then dimpled the skin using the C-Frame tool. The last thing that I did today was debur and polish the edges of the bottom skin.
F902 forward bulkheads with nutplates and snap bushings installed
