Brief Description: Drill Left Fuselage Forward Components
The last set of drilling that needed to be done on the left forward fuselage included the main gear reinforcement panel to the forward bulkhead and the side skin stiffener to the firewall attach clip (angle). The left side forward fuselage structure is done and ready to be taken apart, deburred, countersunk, primed and reassembled. On to the right side...
Drill main gear reinforcement panel to bulkhead
F684 gusset drilled to the steel bracket, firewall and longerons
Side skin stiffener drilled to firewall attach angle
