Brief Description: Drill Hole for Rigt Step; Drill Out Rive
Today I worked on the right side skin. First, I drilled the hole for the step using the hole saw kit that I brough back from Oshkosh. Then I dug up a scrap piece of angle and match drilled it to the tab on the right skin. This tab needs to be curled under to transition the side skin to the bottom and aft skins. I'll save the bend until tomorrow. The other thing that I did today was drill out 3 rivets along the right side that I should not have set until the side skins were in place.
Drill hole for right step and drill scrap angle in prep for bend
Drill out 3 rivets on the right side that I shouldn't have set
