Brief Description: Center Section: Left Corner Rib
Once the right corner rib was match drilled to the bottom skin I inserted the forward and aft attach strips and drilled and clecoed these in place. Then I repeated everything again for the left corner rib.
Right corner rib - forward attach strip drilled and clecoed
Right corner rib - aft attach strip drilled and clecoed
Both corner ribs drilled and clecoed with attach strips
