Brief Description: Center Section: Cleco Ribs/Bottom Skin
Once all of the rib modifications were done I clecoed all of the seat and baggage ribs to the F704 and F705 bulkheads. I then flipped everything over and clecoed the bottom skin in place. Once again, I couldn't get all of the prepunched holes to line up working from the forward bulkhead to the aft bulkhead so I started over. I started by clecoing the center F705 bulkhead to the bottom skin. I then worked my way out from the center and was able to get everything lined up and clecoed together. This section is now ready to be match drilled.
F704 and F705 bulkheads clecoed to seat and baggage ribs
Center section bottom skin clecoed to ribs and bulkheads
