Once all of the top and side components were riveted together I clecoed the F705 bulkhead together and riveted the corners. I couldn't rivet the bar's along the bottom channel where the rear wing spars will attach since I'm still waiting on some replacement bars from Van's. I buggered up the reinforcement bars when I drilled an extra hole in each one and had made a countersink on the wrong side.
