Brief Description: Drill Attach Angles to Left Flap
The next thing I did was use the unibit to ream out a 1/4" hole in the left FL-706A piece for the rod end. Then both the 706A and 706B angles were clecoed to the left flap and match drilled to each other, the spar, and the inboard rib. Time to repeat this for the right flap...
Left attach angles clamped in place
Left attach angles drilled to spar and inboard rib
