Dan's Web Site
Date:  6-10-2003
Number of Hours:  0.50
Brief Description:  Set Inboard-most 5 Rivets - Rear Spar
I drilled out the 5 inboard-most rivets along the rear spar since I buggered them up with the squeezer because of the tight quarters. I ended up enlarging these holes and using oops rivets to fix things up. These rivets were set just fine using the thin profile bucking bar that has the channel in it to fit over the rivets in the web of the rear spar.
Inboard-most 5 rivets along rear spar were replaced
Tight quarters
Tight quarters
