It took me forever to install the right fuel tank on the wing. I did everything twice - all of the screws and bolts. The first time around, the seam between the tank and the leading edge as well as the joint between the tank and the spar had some bulges. I knew right away what the problem was - too much proseal in the way. I removed all of the bolts and screws and then spent a ton of time working to shave, cut, dissolve, remove, etc. excess proseal from along the edges. What a pain. I didn't have this problem on the Left Wing. I guess I got carried away with the proseal on the Right Wing. This was a pain but the final fit is MUCH better now. This wing looks great - no clecoes
Right fuel tank bolted / screwed to wing - Bottom view
Right fuel tank bolted / screwed to wing - Top view
