Brief Description: Proseal Drain and Fuel Pickup Fitting
I mixed up another small batch of proseal and riveted the fuel drain fitting to the skin. I was able to squeeze all of these rivets using the 4", no-hole yoke. I then screwed up. I prosealed and riveted the fuel pickup fitting and anti-rotation bracket to the wrong side of the access plate. They should be on the inside of the plate not the outside. Crap. At least the proseal wasn't set yet. I drilled out the 2 rivets, cleaned everything up, mixed up another small batch of proseal, and then riveted the bracket and fitting on the correct way. Messy and wasted a lot of time. Oh well, no harm done. I need to slow down more and take my time checking everything against the plans.
Fuel drain prosealed and riveted - Inside view
Fuel drain prosealed and riveted - outside view
Fuel pickup prosealed and rivetd to access plate and bracket
