Brief Description: Drill Joint Plate & Inboard LE Rib
Positioning the joint plate and inboard leading edge rib correctly was very difficult because of the tight fit between the skin, joint plate and rib. After much grunting and fiddling, I finally got everything lined up and drilled.
Inboard leading edge rib and joint plate drilled and clecoed
