I had Daisy help me position the fuel tank onto the left wing today. Then I bolted all of the Z-brackets to the spar and screwed in all of the screws along the top and bottom of the spar as well as along the joint against the outboard leading edge. I also spent some time removing all of the blue protective vinyl from the skins.
Fuel tank bolted/screwed to wing. Top of wing complete
Top view of wing with 2 Stevie's - all plastic removed
Bottom view of wing - bottom main skins left off for now
