Brief Description: Prep for First Pro-Seal Session
I prep'ed the parts that I plan to seal during my first pro-seal session. I am not looking forward to this! I will be sealing the fuel drain, the tooling hole in the outboard rib and the fuel pickup fitting. In fitting all of the parts together I decided to use a blind rivet in the one hole that I couldn't squeeze. This turned out to be on the outboard edge of the drain flange. Shouldn't be a problem since this will get plastered with proseal on the inside. Once all of the parts were scuffed up and cleaned with MEK, I laid everything else out for easy access during my first proseal session.
Prep drain - Use blind rivet in the one hole that I can't squeeze
Prepare cover for tooling hole
Pro-seal, safety equipment, and scale ready to go...
