Brief Description: Z Brackets Drilled;Ribs & Baffle Removed
After all of the Z brackets were drilled using the pre-punched baffle as a guide, the end ribs and baffle were removed from the spar. The final task for today was to unbolt the Z brackets from the spar so they can be deburred and primed.
Z brackets all drilled and end ribs and baffle removed
