Dan's Web Site
Date:  8-4-2002
Number of Hours:  0.75
Brief Description:  Bend Tabs on Trim Tab Skin
I used the same wood blocks that were used to bend the elevator cutout tabs to bend the small end tabs in the trim tab. The bends were pretty challenging since they are so small. I used double-edged tape to prevent the blocks from slipping around on the skin. Pulling this tape off proved to be a challenge. When everything was finally all said and done, my first edge actually turned out pretty good - nice and straight!
Bottom end tab bent over wood blocks
Both end tabs bent
Both end tabs bent
