Brief Description: Install Nutplates for Voltage Reg and Man Press
I decided to replace the nuts that I used to bolt the voltage regulator and manifold pressure sensor to the firewall with nutplates. Both of these components will probably fail someday and I want to be able to remove these myself from inside the cabin and not have this become a two person job. Should have done this originally.
Nutplates for voltage regulator and manifold pressure sensor installed on firewall
