Brief Description: Install RG400 to GTX-327 Backplate
My final task for today was to solder some RG400 to the right-angle BNC backplate fitting for the Garmin GTX-327 transponder and then clip the fitting to the backplate itself using the washers/circlips supplied in the install kit. Just followed the cookbook in the GTX-327 install manual.
RG400 transonder antenna cable soldered to 90 degree fitting and attached to GTX-327 backplate
