Brief Description: Connect 6AWG from Bat Relay to Main Buss
I ran the 6awg power cable from the switched side of the battery contactor up the left side of the battery box, through the firewall where the 18awg alternator field wire goes through, and then through the subpanel just above the main buss. In the 3rd picture below you can also see the 14awg wire that I installed from the main buss to the diode that will then feed the endurance buss. I installed a rubber boot over the connection at the main buss. I'm not quite sure what to do about all of the exposed terminals, shunts, copper connections, etc around the battery and starter contactors yet, if anything.
6awg bolted to switched side of battery contactor
6awg power line running through the firewall
6awg running through the sub panel and connected to the main buss. 14awg is also connected and runs t
