Brief Description: Connect Wires for Low-Voltage Warning Lamp
My final task for today was to hook up the low-voltage sensor / warning lamp. This was done by soldering the 22 awg wire from terminal 5 on the voltage regulator to one of the tabs on the amber low-voltage warning lamp on the panel, and then also soldering the 22 awg wire from terminal 3 on the voltage regulator to the other tab on the lamp along with another 22 awg wire that runs to the main bus with a 2 amp fuse. Daisy had to help me with the soldering since I needed a third hand to hold everything - one for the soldering iron, one for the solder, and one to hold the 22 awg wires in place. I'll have to buy some small alligator clips sometime to help hold things while soldering. Heat shrink tubing was placed over the soldered joints.
22 awg wires from term's 3&5 on voltage reg soldered to low voltage lamp
22 awg wire from 2 amp fuse on main bus also soldered to low-voltage warning lamp
