Brief Description: Install Shunt and 60amp Current Limiter
I received my replacement ammeter shunt from Dynon today. I ordered a new one since I cracked the plastic base on the original one while bolting it to the firewall. I also received my order from B&C Specialty for a 60 amp current limiter and base that will be used to protect the B-lead wire.
After I reinstalled the Dynon ammeter shunt I decided to mount the current limiter right next to the shunt and connect them with two copper strips. I then connected the other end of the current limiter to the unswitched side of the starter relay, which is really the switched side of the master relay, using a short length of 2 awg wire.
Alternator B-lead connected to Dynon shunt connected to 60 amp current limiter connected to contactor
