Brief Description: Remove Plastic Spiral Tubing from Low Pressure Lin
After viewing a ton of RV's at Sun 'n Fun last week and finding none with any extra chaffing protection around their low pressure brake lines, including the Van's demonstator planes, I decided to remove the plastic spiral tubing from mine. The lines are so smooth that I doubt they will chafe against the rudder pedal support tubes or anything else for that matter.
Plastic spiral tubing removed from right brake lines
Plastic spiral tubing removed from left brake lines
