Next I installed the Dynon Cylinder Head Temperature (CHT) probes. These are just spring loaded probes that insert into hole in the bottom of each cylinder head. The spring keeps tension on the slotted nut so they don't back out.
CHT probes installed on right side - cylinders 1 and 3
CHT probes installed on left side - cylinders 2 and 4
