Brief Description: Prime, Remove Masking, Install on Fuselage
This morning I wiped off all the excess Wonder-fil pinhole filler, cleaned and vaccumed everything and primed the canopy frame again with SW 988 rattle-can primer. It came out looking much nicer than the first time around!The right side still has some minor high's / low's if you catch it in the right light but I am very satisfied with how the corners turned out. They look and feel incredibly smooth, and you can't tell that there are plexiglass, fiberglass, aluminum, and filler materials all coming together at these points. It all looks like one material.Definitely airworththy at this point. One final iteration of sanding / priming just before the final finish paint goes on and this will be absolutely perfect!Once the primer dried I removed all of the masking tape and paper and had Daisy and David help me install the canopy on the fuselage. Nice! I am VERY happy with how this came out!
Canopy primed again - not too bad from a distance
Canopy primed again - not too bad up close either!
