Brief Description: Sand Rage; Apply a 2nd Layer of Filler
My fingertips are raw from all the sanding I did today with 40 grit but things are looking much nicer in these transition areas. I used the 40 grit to do most of the shaping, which are the light blues areas you see below. However, there were still a few spots that needed a bit more filler so before wrapping things up for today I added a 2nd layer of Rage to these areas, which are the darker blue spots. More sanding in store for tomorrow if my fingers can hold out.
The light blue is the first layer, the darker blue a second layer of filler
Right side - layer one sanded with layer 2 waiting for tomorrow
