Brief Description: Fabricate/Install Line from Valve to Elec Pump
Before jumping back into the sanding and fiberglass work I decided to finish up the fuel lines in the cabin. I needed a change of pace so I dug out the new 3/8" tubing that I purchased at Oshkosh this year and started bending. It took several iterations until I finally had one that would fit between the fuel selector valve and the electric fuel pump, not touch the floor up front, and not have any stressed areas. The fittings meshed perfectly which made screwing the nuts on an easy task. The fuel lines inside the cabin are done!
Several failed attempts along with successful piece at top with fittings
