Brief Description: Sand, Clean, Micro Rudder & Vertical Stabilizer Ti
Today I sanded the vertical stabilizer and rudder tips. There was a small amount of flox that seeped through the joints that needed to be sanded. I also sanded about a half inch along the length of each side of the joint and around the rivets. Everything was then cleaned with Acetone and microed. I also covered the honeycomb cap on the vertical stabilizer with micro.
