Brief Description: Sand the Flox Filler - Ready for Fiberglass
Did I mention that Flox is not very easy to sand? My fingertips are raw sanding this stuff with 40 grit! Matt made quick work of the heavy areas with a sanding drum in the dremel tool but most of the work had to be done by hand. This will provide a nice base for the fiberglass. The Flox covered all of the aluminum clips and tabs nicely.
