Brief Description: Bolt/Torque Lower Center Two Engine Mount Bolts
I received the 4 large washers and the 2 longer AN6 bolts I ordered from Aircraft Spruce today.Adding 2 large washers between the engine mount and firewall for each location was a perfect fit. Once the bolts and washers were in I torqued the castle nuts to 185 in-lbs and installed the cotter pins.The engine mount is permanently in place!
Lower center two AN6 bolts installed with large washers
