Brief Description: Install TG-10 Heater Vent; Drill Hole for Cable
Today I drilled a #10 hole in the F-601N-R firewall stiffener for the CTA-740 push/pull cable for the heater vent using a right-angle drill. I purchased some high-temp RTV and used this to seal the TG-10 heater vent to the firewall before bolting it in place.
#10 hole drilled in F-601N-R stiffener for CTA-740 push/pull cable for heat vent
