Brief Description: Drill Ribs for Screws to Secure Duckworks Kit
The Duckworks kit came with another paper template that Heather cut out and glued to a piece of cardboard. It is actually glued to the backside of the cardboard which was fine. All I really needed that for was to punch a couple of holes through the cardboard to locate where to drill the ribs for the screws that are needed to secure the Duckworks mounting plate. Once the template was in place, I drilled through the holes in the cardboard and through the rib. The template was then moved to the next inboard rib and used to drill those 2 holes as well.
