Brief Description: Install Transducer Manifold; Seal Brake Reservoir
Today I installed the AN fittings and Dynon EMS-D10 fuel and oil transducers on the transducer manifold and bolted the assembly to the firewall. I used EZTurn on all of the pipe fittings.I also removed the brake reservior to install the Reservoir Dog stop valve on top and to seal the firewall around the unit with High Temp RTV.
Transducer manifold installed with oil and fuel pressure fittings and transducers
Brake reservoir reinstalled with the Reservoir Dog stop valve and sealed to firewall
Inside view of brake reservoir - sealed on this side too
