Brief Description: Right Wing Tip - Install Nutplates for Position Li
I used the #6 nutplate jig to drill the rivet holes for the aft nutplate but I had to use an actual single lug nutplate as the jig for drilling the rivet holes for the 2 side nutplates. Once the rivet holes were drilled I used the microstop countersink without the cage to countersink for the flush rivets. Then I had to actually buck the rivets to install the nutplates. It's been a long time since I had to do that but it went fine by myself since I could reach both sides without any problem.
Drilling rivet holes for #6 nutplates for position lights
#6 nutplates installed for position lights - inside view
#6 nutplates installed for position lights - outside view
