Brief Description: Left Wing Tip - Cutout for Whelen Position Light
I used the dremel to make the cutouts for the Whelen position light. A cutoff wheel worked well for the straight cuts and a cutting bit and sanding drum worked well everywhere else.
Left wing tip - holes drilled for Whelen position light and base traced
Left wing tip - cutout made for Whelen position light
Left wing tip - Whelen position light base clecoed in place
