Brief Description: Wing Tip - Micro Top Reinforcement Strip
Today I sanded the top inside flange of the right wing tip along with the aluminum reinforcement strip. Then I vacuumed up the dust, cleaned everything with Acetone, and mixed up a small batch of epoxy with micro in it. I then used a small paint brush to spread the micro on both the wing tip flange and the aluminum reinforcement strip and clecoed everything together. The sledge hammer is just providing a little extra clamping force in between a couple of the clecoes where the aluminum strip was puckering a bit.
Right wing tip - top flange and reinforcement strip sanded
Right wing tip - top flange and reinforcement strip microed and clecoed together
